Full Version: Ac Air Conditioning Smelling Bad =(
Toyota Matrix Owners Forum > General > Car Care
swagsplash89
2003 Toyota Matrix 103,000 miles ..
When I turn my AC on, a weird smells comes out for a few minutes. It smells like vomit. I hate it soo much. What do I do??
HaZzArD
change cabin filter
XR2003
 ^ x2 also from time to time use the A/C w/out recirculating (MAX A/C) the air. Moisture will remain on the condenser and bacteria will cause that nasty mildew smell.
The a/c cabin filter is locates behind the glove compartment.
keithvibe
QUOTE (XR2003 @ Jun 9 2010, 05:23 AM) *
^^^ this
To prevent it, turn off your ac about 3-5miles from your final destination, but leave the fan on HI to dry out the condenser.
MatrixDom
Last but not least, don't go to Toyota so they charge you 50$ to replace your cabin air filter. Go to a local shop, buy your CAF for less then 20 bucks, go home and find a phillips head screwdriver. Open your glovebow, see that screw holding it at the right ? Take it off, everything else is straightforward. Still can't believe how Toyota robs money from doing this simple task.
Screw? You needn't remove any screws. It's just a plastic clip.
MatrixNubee
QUOTE (MatrixDom @ Jun 9 2010, 07:07 AM) *
QUOTE (dnm @ Jun 9 2010, 07:19 AM) *
No screws, just 2 tabs, 1 one each side of the front cover. Push both tabs inward and it will release and pop out forward. Then replace filter by sliding new filter into the compartment making sure right side is facing UP. Then press cover back on, it will snap back on.
Filter is only 15 bucks at auto shops. Dealer charges 4 times that amount, so don't get there ever.
XR2003
uhm, you do need a phillips screw driver to remove the glovebox to GET TO the a/c cabin filter.
MatrixNubee
QUOTE (XR2003 @ Jun 9 2010, 05:23 PM) *
Hahah oh yeah, well for that you DO need the screw driver rolleyes.gif my bad lol
swagsplash89
Thanks guys ! Your help is really apreciated. Im going to get this job done asap. Thanks again Matrix Owners :-)
Acecooper
It seems that your air con needs to clean out. The fact that you need to set a time when you want to do the maintenance. Hopefully, it would be a big help.
XR2003
QUOTE (Acecooper @ Aug 30 2010, 10:47 PM) *
initialTB
i think this will work http://www.youtube.com/user/scottykilmer#p/u/8/VrVc_FXrbHY
