Dc Sports Header Installation Question!
6 replies to this topic
#1 Traumaforyou
Traumaforyou
  • 20 posts
  • Vibe
Posted 31 December 2016 - 09:20 AM
I just purchased the DC sports header for my 2006 pontiac vibe. I am unsure as to weather when I do install if I will need any gaskets or new bolts since the new header didn't come with any. Any help would be greatly appreciated!
#2 thebarber
thebarber
    brapapapapapap
  • 12,754 posts
  • Echo
Posted 02 January 2017 - 06:04 AM
1. Whether
2. You can reuse the manifold gasket at the block, but you're best to get a new donut gasket for the midpipe side
thebarber%20winter%20echo%20signature_zp
#3 danimal86
danimal86
  • 1,146 posts
Posted 05 January 2017 - 10:26 PM
manifold gaskets are cheap, just get a new one.
Thing was a beyatch to install (have a scar on my hand from removing the existing manifold from the brace on the underside of it).  Good luck, it can be a diy, but a pain.
Installed: DDM 4500K 55w HID's Morimoto Mini H1 Bi-xenon Projectors (XB-35 Bulbs & Denso Ballasts),(E-Bay) SRI Injen CAI, Pioneer Avh-P3200DVD (With add-on bluetooth & Navi) Avic-X940 Bt, Infinity Components (front) RF Prime 6.5 (rear), DC Header, JL 500/1 and 10w6, TRD Axle Back Exhaust, Camcom, TRD STB, Progress RSB, Scion TC Wheels Stock 16" 5-Spoke, Scanguage II, VLED V3 Triton Brake Lights, VLED: Interior reverse and flashers, Escort Smart Radar (Android)
Next: Fx-R 3.0 retrofit LS460 Retrofit, Rear Disc Conversion
#4 Traumaforyou
Traumaforyou
  • 20 posts
  • Vibe
Posted 21 January 2017 - 04:45 PM
Should I be expecting the donut gasket at the converter to be welded on?
#5 pins_and_wheels
pins_and_wheels
  • 41 posts
  • Interests:bowling, cars, girlfriend, not necessarily in that order.
Posted 17 February 2017 - 09:32 PM
Not necessarily, but can expect it to be a bit tattered. I find it easier drop the manifold with the passenger axle out of the way and drop the manifolds out of the bottom. If you need bolts, they're pretty cheap through Toyota, or at least they are through my local dealer: Jimwhitetoyota.com
Edited by pins_and_wheels, 17 February 2017 - 09:46 PM.
#6 LannVouivre
LannVouivre
  • 501 posts
  • Gender:Female
  • Vibe (base, FWD, auto)
Posted 17 February 2017 - 10:56 PM
I've only ever brought the manifold out the top.  The O2 sensor will be extremely tight, even more so if your classmate crossthreads it back in.
The donut shouldn't be stuck.  Try not to damage it.  It should be reusable, as it can reshape a little bit to reseal from what I can tell. (removed mine 3 or 4 times with no issue).
I think you can re-use the steel one unless you accidentally split up the layers, but I'm not going to recommend it because it doesn't seem to reseal as well.  A flat graphite gasket, however, will almost always fall apart if you remove it in my experience.
...Did you try hitting it with a hammer?
#7 dnm
    captain pants
  • 10,267 posts
  • Interests:Toejam, but not Earl; sequels to bad movies; hair in the drain; dog farts; and broken promises.
  • 2003 Matrix XRS/2004 Matrix XRS/2007 Supercharged FJ Cruiser/2004 Audi S4/1994 Toyota Supra TT/1983 Yamaha XS400/and the real gem: 1997 Nissan Pathfinder, bιtches.
Posted 18 February 2017 - 10:16 AM
Don't reuse the donut gasket.  Ever.  Unless it's damn near brand new.
It isn't welded on; you can't weld them.  It may appear that way though based on how badly it gets stuck.  But if you buy a new one, it doesn't matter; just leave it attached to the old exhaust manifold.
And as others have said, exhaust gaskets are cheap (like $12).  Just buy a new one.
