Turbo Woes - Revisited
Posted 13 July 2012 - 06:51 AM
My AFRs were good at idle, 13.x. Engine temp looked oK but then again she only ran at most 10min. Ideas on what to check? I'm guessing something went wrong with the ECU or tune.
Posted 13 July 2012 - 06:56 AM
Posted 13 July 2012 - 07:11 AM
Posted 13 July 2012 - 07:32 AM
Posted 13 July 2012 - 07:35 AM
I can get a before/after exhaust note this weekend if you all think that will help.
[edit] Just googled exhaust leak symptons; some of those fit, some don't *and* my community is under construction and only 1 layer of asphalt. Exposed manholes all over the place. I tagged one a few weeks ago but didn't notice anything until now.
Edited by dB_Outlaw, 13 July 2012 - 07:41 AM.
#6
Posted 14 July 2012 - 03:44 PM
Posted 20 July 2012 - 06:23 AM
I refuse to think it's anything catastrophic but I don't have money to get it looked at. Maybe next month. Until then, it'll sit in my garage with the hood up; the universal sign of distress.
#8
Posted 29 July 2012 - 11:28 AM
Exhaust leak?
[edit] after watching that I see I'm not making any boost when I rev it in neutral...
Edited by dB_Outlaw, 29 July 2012 - 11:33 AM.
#9
Posted 29 July 2012 - 12:17 PM
also you shouldn't have boost when you rev the engine, it should go close to 0.
Project "2.0L": Updates
Pictures of Project 2.0L
Video's of Matrix
Ex-DSM Member #2
#11
Posted 29 July 2012 - 07:18 PM
Have you driven it since then? Does it drive like it the previous times?
Video's of Matrix
Ex-DSM Member #2
#12
Posted 30 July 2012 - 04:53 PM
#14
Posted 22 August 2012 - 03:56 PM
#15
Posted 22 August 2012 - 04:02 PM
bkr7e is 2 ranges colder than an oem 1zz calls for -- this may be perfect for a built turbo application like you have going on, but a good identifier would be any indication of carbon fouling or overheating on the plug.
#16
Posted 22 August 2012 - 04:59 PM
carbon deposits indicate your heat range is too cold, that white crap indicates that your heat range is too hot.
#18
Posted 23 August 2012 - 05:46 AM
Side comment. Both cylinders 1 and 2 had a loose screw beneath the spark plug. WTH is this? I assume the other 2 plugs have it as well.
#19
Posted 23 August 2012 - 09:55 AM
