Increased Hp
46 replies to this topic
#1 valmare
  • 15 posts
  • MRS 2zzge
Posted 19 February 2012 - 05:27 PM
I'm sure this has already been discussed but I searched and couldn’t find a good answer. I have already added a short ram air intake and flow master to my 04 XRS. I want to continue to increase HP but I am cheap as well. What’s the next best thing for the money? So far all I have spent on the 2 upgrades is $350.00
#2 thebam
  • 1,732 posts
Posted 19 February 2012 - 06:24 PM
This has been covered countless times. But, the only mod that will give u real gains is FI.
I forgot who it was on here, but I think they got 215 on NA. With full bolts on
The intake and exhaust maybe gave u 5 HP.
#3 valmare
  • 15 posts
  • MRS 2zzge
Posted 19 February 2012 - 06:33 PM
FI?
#4 Roxtar
    ಠ_ರೃ
  • Site Admin
  • 13,187 posts
  • Interests:porsches, wrenching, racing
Posted 19 February 2012 - 06:35 PM
forced induction. turbocharging, supercharging, or nitrous oxide injection.
2005 Phantom XRS. Current Mods Updated August 10, 2009.
#5 thebam
  • 1,732 posts
Posted 19 February 2012 - 06:42 PM
There's a DIY turbo build in the how to section. Runs u about 2K
#6 Crazzyboy
  • Silver Member
  • 1,371 posts
Posted 19 February 2012 - 06:44 PM
what flowmaster did you get?
2006 XRS Phantom Gray:
K&N short ram, AEM Dryflow Filter; Magnaflow muffler; Ported Header; TB bypass; ES Motor Mounts; MWR Water Pulley; TRD Oil Cap; TRD Radiator Cap; TRD Sway Bars(F&R); TRD Strut Brace; UR Rear Lower Bar; Tein H Techs; TWM short shifter, bushings, A6 shiftknob; Achilles ATR Sport 225/40/18; 8mm rear spacers; StopTech Slotted Rotors F/R; 18% Tint AllRound; SC300 Horn; Debadged "TOYOTA"; Sharkfin Antenna; "Matrix" Doorsills; Silvania SSUltra 9005, 9006; VLEDS Really Effin Bright Reverse LEDs.
2007 Nissan Versa SL: Silver bone stock
#7 valmare
  • 15 posts
  • MRS 2zzge
Posted 19 February 2012 - 07:16 PM
Just the 40 series. And i'm not going with FI. Way too much $ for me. Guess i'll just keep nicle and dimming it over time with small mods.
#8 Salsa Guy
  • 1,876 posts
  • S/C 4WD
Posted 19 February 2012 - 07:18 PM
You need to pay to play!
05 Matrix XR 4WD & S/C. The Few, the Proud!
MODS:
Performance: TRD SC, AEM UEGO Wideband w/Auber Gauge, Vibrant/Magnaflow Cat-back, Oil Catch Can, Voltage Stabilizer/Ground Kit, DC Sports Strut Bar, Auber Boost Sensor/Gauge, Tranny Cooler, Alutec Lightweight Crank Pulley.
Others: DRL Mod, Fog Light Mod, Sunroof Auto Stop Mod, Hella Horns, Ceramic Brakes, VVTi Logo Ignition Coil Cover. Lowering Springs, Fog HIDs
#9 Crazzyboy
  • Silver Member
  • 1,371 posts
Posted 19 February 2012 - 07:22 PM
Ah I've been contemplating a 40 series. How does it sound? the only way to get signifigant power gains is with lotsa cash. Try poking around monkeywrenchracing.com for some ideas. Lightweight pulleys help a little. Super light wheels will also help are obviously money. Lightweight flywheel. These are probly the cheapest options comming to mind.
#10 kpace
    formerly 1337trix
  • 6,339 posts
Posted 19 February 2012 - 07:24 PM
bro, get a whistle tip
it's got that wooo woooo
#11 Salsa Guy
  • 1,876 posts
  • S/C 4WD
Posted 19 February 2012 - 07:35 PM
Remove the engine cover...that's 10 HP!
MODS:
#12 valmare
  • 15 posts
  • MRS 2zzge
Posted 19 February 2012 - 07:42 PM
What about ignition box's/kits?
#13 Evilthorne
    Are you "Reddy"
  • Silver Member
  • 10,678 posts
  • Interests:Cars
  • Subaru
  • WRX STI
Posted 19 February 2012 - 07:48 PM
No chips, engine block kits, grounding wires or other garbage. Save your money, if you want something buy light weight pulleys, or PnP your header.
click my sig for my registry
#14 Roxtar
    ಠ_ರೃ
  • Site Admin
  • 13,187 posts
Posted 19 February 2012 - 07:50 PM
you have coil-on-plug ignition. "ignition boxes" won't do anything. performance coil packs may gain you a couple of horses, but at $100 each, they aren't really worth it.
#15 CASH XRS
  • 1,173 posts
Posted 20 February 2012 - 08:49 AM
hahahahaha. Or that "turbo sounding exahsut tip". O man the things that are out there lol.
How good of a job does a full pulley setup do? I've heard it helps and I've heard it makes your engine work harder?
05 Indigo Ink Pearl XRS, so far, Eibach Sportline springs, Tokico HP Blue shocks, Greddy Evo 2 axle back exhaust, Injen CAI, TWM Short shifter with weighted knob.
XRS wheels powdercoated (coming soon), Indigo colored headlights thanks to Rivot!, interior panels painted Speedway Blue.
I Love My Wagon.
#16 kpace
    formerly 1337trix
  • 6,339 posts
Posted 20 February 2012 - 10:03 AM
pulleys can do a couple things
1st is remove weight, similar to performance gained when getting lighter wheels
2nd is you can get them in larger sizes which will underdrive the accessories(ligthen the workload)... so if you have a big a** stereo system you dont want to be getting an alternator pulley, but if you're a minimalist than you can afford to do that. Same goes with the waterpump pulley
Waterpump pulleys are built for normal road going, so they're at peak performance at mid RPM's for long highway driving.... however autocross or road racing causes the engine to rev higher, the pulley spins faster and you could get cavitation, meaning that the pump is spinning past its peak and is actually being less efficient than at a lower RPM(overheating)
so if you get a waterpump pulley, it can make the waterpump's peak effeciency at higher RPMs without hurting anything... hopefully i've explained it right
essentially - lots of ICE and aftermarket pulleys = lots of dumbass
Edited by 1337trix, 20 February 2012 - 10:04 AM.
#17 infuzeyou
  • 126 posts
  • Corolla S
Posted 20 February 2012 - 11:28 AM
For a N/A build, I recommend starting with:
cold air intake
performance header
custom mid-pipe or prefab mandrel-bent cat-back
underdrive alt. pulley (if you're not running any heavy electrical items)
lightweight flywheel
those are pretty much the basics for N/A, anything more and you'll want to start thinking about aftermarket engine management systems and dyno tuning, which can get pricey quick.
^^this
By the time I finish my s/c build, I'll be around $7,000 just in engine performance parts and dyno tuning.
Performance Mods: K&N Typhoon SRI, Megan Racing coilovers, DC Sports strut bar, Alutec lightweight crank pulley, R1 Concepts cross-drilled/slotted rotors, Hawk HPS pads, NRG voltage stabilizer/grounding kit, Optima Red Top battery
Other Mods: Chrome w/black mesh grille, H9 chrome projector headlights, 5000K 35W HIDs, 2nd gen Altis LED tails, AVS window visors, stubby antenna, Tc armrest, Räzo quick-shift knob, Enkei Super 7 18" wheels, Avital remote start w/ trunk pop & lock/unlock, LED Swap: every single bulb replaced w/ LEDs (interior & exterior), plus engine bay LEDs and under-dash LED bars
Coming soon: JP header, Vibrant axle-back exhaust, high-flow catalytic converter, Weapon-R oil catch can, TRD CAI
#18 CASH XRS
  • 1,173 posts
Posted 20 February 2012 - 12:29 PM
haha, ok, well I will be putting in an aftermarket head unit soon and maybe upgrading the speakers and woofer eventually, but nothing insane. So I think I'd be OK with an alternator puller and the water pump pulley is definitely something I could do. I was thinking of going with both the alternator and water pump pulley. According to MWR you gain roughly 6-7 hp and 4 lb of tq, all you have to do is get a belt that is 2 inches longer. Worth the ~$200?
I Love My Wagon.
#19 valmare
  • 15 posts
  • MRS 2zzge
Posted 20 February 2012 - 07:15 PM
OK. Another question. The header on the 2zz is already an upgrade right? Can I get better?
#20 Crazzyboy
  • Silver Member
  • 1,371 posts
Posted 20 February 2012 - 07:43 PM
The stock 2zz header is quite good to begin with. Your cheapest route is to port it. The gains from DC is debatable and PPE is a large wad of cash, but those who have it, swear by it
