Shiftin To Reverse
23 replies to this topic
#1 Stephi Matrix
Stephi Matrix
  • 102 posts
  • Gender:Female
  • Matrix S
Posted 13 February 2012 - 05:37 PM
In my 10 matrix s when i try to shift to reverse it wont go into gear... I read in the toyota manual that i just have to put it ino first back to neutral take out clutch and try again... Anyone else have a problem w it? s*** is annoying! Its done it since i drove it off the lot
#2 kpace
kpace
  • 7,196 posts
Posted 13 February 2012 - 07:40 PM
my 03 will only go into reverse after selecting 2nd gear
clutch in, try reverse... if it doesnt go, choose 2nd gear and try again
#3 thebam
thebam
  • 1,768 posts
Posted 13 February 2012 - 07:43 PM
Same here. Sometimes mine won't go into reverse or 1st. So I just put it in any gear, and switch back to the gear that is needed and all good
#4 Stephi Matrix
Stephi Matrix
  • 102 posts
  • Gender:Female
  • Matrix S
Posted 13 February 2012 - 08:34 PM
Yeah thats what i do too... Find it annoying at times since its every time i try to reverse... Oh well hah :x
#5 CORZRYDE
CORZRYDE
    A bit of a whiner ;)
  • 5,020 posts
  • Matrix XR SC w/ C60 swap
Posted 13 February 2012 - 09:09 PM
Really? That many peeps having this issue? Never experienced this in my 07 5 spd & I'm pretty rough on my tranny. Always goes into reverse from any gear I've tried, (as I recall). Would the shifter link or bushings cause this?? :blinksmiley:
2007 Matrix XR~THE LOOK~Speedway Blue~TRD oil cap~TRD CF engine cover~TRD Grille~TRD STB~Hella Horns~Tein S-Techs~Progress RSB~MB Motorsports Boost Wheels (Gold)~Ichiba spacers (15mm F, 20mm R)~colour matched projector retro headlights .....................
................................~THE POWER~TRD SC~TRD CAI~DeatschWerks 370cc injectors~GReddy E-manage Ultimate~MWR pnp harness~AEM UEGO In Line Wideband~URD AFR calibrator~C60 transmission swap~MWR Ultralight flywheel~Spec stage 1 clutch~Energy Suspension motor mount inserts~Speed Source brass shifter cable bushings~Speed Source extended push rod~TRD axle back exhaust
a295f0dc-55d0-4ddb-85d9-92ba80bf4be7_zps
#6 TKS09Trix
TKS09Trix
  • 522 posts
  • Interests:Kids, Wife, Cars, Xbox, Bruins, Raptors.
Posted 14 February 2012 - 08:43 AM
Mine is a b**** to go into reverse daily. Even trying to go into second or first then back to reverse doesn't always work.
#7 Stephi Matrix
Stephi Matrix
  • 102 posts
  • Gender:Female
  • Matrix S
Posted 14 February 2012 - 09:45 AM
Thats how mine is! Wtf?!
#8 shawngeeves
shawngeeves
  • 949 posts
Posted 14 February 2012 - 11:01 AM
Same issue here. Once at a stoplight it refused to go into any gear at all. Luckily that only happened once.
#9 Stephi Matrix
Stephi Matrix
  • 102 posts
  • Gender:Female
  • Matrix S
Posted 14 February 2012 - 11:46 AM
i yell at mine all the time when it acts up...ive gotten a good amount of stares :)
#10 CORZRYDE
CORZRYDE
  • 5,020 posts
Posted 14 February 2012 - 02:26 PM
^ You guys are using your clutch, right? :rolleyes:
#11 TKS09Trix
TKS09Trix
  • 522 posts
Posted 14 February 2012 - 03:20 PM
What's this "clutch" you speak of? Yes of course we are. It's just another 1 of the million Toyota quality problems.
#12 shawngeeves
shawngeeves
  • 949 posts
Posted 14 February 2012 - 03:34 PM
Yes. :tonguesmiley:
My clutch is not in the best of shape anyhow. It occasionally grinds in most lower gears.
#13 CORZRYDE
CORZRYDE
  • 5,020 posts
Posted 14 February 2012 - 04:30 PM
Yes. :tonguesmiley:
:blink: Umm, that's not your clutch. Sounds like your synchros are going.....going....gone?? :lol:
No worries, my 2nd gear is a little notchy, but I'm to blame for that one...:whistle:
#14 shawngeeves
shawngeeves
  • 949 posts
Posted 14 February 2012 - 04:47 PM
No worries, my 2nd gear is a little notchy, but I'm to blame for that one... :whistle:
Sorry, perhaps I did not properly describe the issue. Often, when shifting into reverse, or first gear, I hear something akin to a light growl/whine and the gear doesn't properly engage. As soon as it does, the sound is gone.
I'm not getting the kind of audible noise you find through examples of "Clutch grind" on YouTube. (Can you tell I'm uninformed on the matter?)
I suppose it's just something else I'll have my mechanic take a look at it when I can afford to do something about.
Edited by shawngeeves, 14 February 2012 - 04:49 PM.
#15 Stephi Matrix
Stephi Matrix
  • 102 posts
  • Gender:Female
  • Matrix S
Posted 14 February 2012 - 04:58 PM
My car isnt even a yr old and im def not grinding... Its something they specifically put in their manual...
Just a flaw i suppose.. Even tho i think its bs the stealership and toyota is ok w it
#16 CORZRYDE
CORZRYDE
  • 5,020 posts
Posted 14 February 2012 - 08:33 PM
Wait, they said it's normal?? I still don't understand why this is happening to you guys & why it's considered "normal" according to the stealership. Everyday I back into my parking spot @ work & into my driveway/garage @ home. I'm either shifting from 1st to reverse or 2nd to reverse, depending on the scenario, but either way, I'm not having this issue.
I'd say start bitching to the dealership & tell them it's interfering with your driving or make it sound like it's hazardous. If they don't comply, take it to the next level. There's no reason why this can't be resolved.
BTW, I work @ TMMC where the trix is built & this is the first time I've ever heard of this issue.
#17 Stephi Matrix
Stephi Matrix
  • 102 posts
  • Gender:Female
  • Matrix S
Posted 14 February 2012 - 11:27 PM
Its in an owners manual even.. It just tells you to like re- shift... I was like thats lame
Def gunna look into it more tho... Since i only have 25k on my car and i plan on driving it for a while
#18 CORZRYDE
CORZRYDE
  • 5,020 posts
Posted 15 February 2012 - 11:29 AM
Wow. Guess I'll have to check my owner's manual to see what it says. Mabye it's just "normal" for the 2nd gens?? I dunno...
#19 Stephi Matrix
Stephi Matrix
  • 102 posts
  • Gender:Female
  • Matrix S
Posted 15 February 2012 - 12:19 PM
Idk its shady haha
#20 Navarone
Navarone
  • 437 posts
  • Interests:photography, computers.
Posted 01 March 2012 - 09:32 PM
This happens on EVERY manual I've ever driven. Just try again, or put it in first and roll a tiny bit then put it back in reverse.
Seems like a non issue.
