Need Help Finding The Right Size Tires!
4 replies to this topic
#1 Trix4Life
  • 409 posts
Posted 19 February 2011 - 12:23 PM
Hi guys,
So over the holidays i got these wheeles as a present and i want to install them on the Matrix:
http://www.nlmotorin...-p/00268108.htm
Now, my question is what are the tires or how do i find the tires that would fit these??
Basically i am looking for the size of tires that would fit these wheeles
Thanks in advance,
Naz
Edited by Trix4Life, 19 February 2011 - 12:25 PM.
"When you lose yourself - you lose everything"
#2 CrailTrixXR
  • 1,329 posts
  • Interests:Hockey, soccer, snowboarding, and some car stuff here and there. Oh and craft beer.
Posted 19 February 2011 - 06:32 PM
Try finding the rims on tirerack.com they could show you the tires you would need for them. It says the rim is 16x8 so convert 8inches to cm????
Current Mods
Custom magnaflow exhaust, TRD front upper strut bar, H1 UR Retrofitted Projectors with Apollo shrouds 5K, 6K HID Fogs, Cupholder LED's, Underseat LED bars, 5% tints in rear windows, 17"x7.5 Ikon rims and Canuck lowering springs w/ stock struts.
#3 Trix4Life
  • 409 posts
Posted 19 February 2011 - 07:33 PM
Thank-you
16 X 8 = 406.4 mm x 203.2 mm
Hmmm...
Edited by Trix4Life, 19 February 2011 - 07:33 PM.
#4 Trix4Life
  • 409 posts
Posted 19 February 2011 - 07:43 PM
SO i can use tire size: 205 / XX / 16 correct??
Original tire size that car came with: 205/55/16
Edited by Trix4Life, 19 February 2011 - 07:45 PM.
#5 madbikes
  • 3,827 posts
  • Interests:Glow-engine R/C cars, Guild Wars, Taiko, Cars
Posted 20 February 2011 - 12:31 AM
You need to take the offset of the rim and the car's ride height into account. Stock 16" rim's offset is +39.
245 will be the best fit on a 8" wide rim, but there isn't a whole lot of tires. 245/50/R16 will have a few street tires to choose (I just try tirerack) and track tires. You'll be about 3% faster than what the speedo says. If you don't mind stretching the tire, you can put 225/45/16. But you'll be almost 4% slower that the speedo. and bring the car a bit lower.
04 Matrix (4-speed auto)
-Winter "rain" mode (stock airbox minus intake snorkel)
-Pivot Blue Raizin Voltage stabilizer and Ignition Ground system
-Philips G4 ballast + "6000K "Philips "Ultinon" HID
-Powerslot slotted rotors (new design) w/Hawk HPS pads
-Tokico Blues + stock springs
-05+ rear lights
-Progress RSB
-TRD STB
-Technafit SS brake lines
-Magnaflow full cat-back
-Energy Suspension Lower Control Arm Bushings (a must if you're lowered)
12' Golf (5-speed manual)
Coming soon: AWE Tuning cat-back exhaust, Carbonio CF CAI and probably a tune.
