Great Headlight Sealant For Proejcts!
20 replies to this topic
#1 RcMannAE86
  • 1,072 posts
  • Matrix XR-T
Posted 14 December 2010 - 06:39 PM
I have run across a great sealant for use in all different types of headlight projects that require baking the housing and resealing. It is the OEM sealant from Nissan/Nismo. It is a highly recommended sealant that was made for sealing headlight housings back up after opening them.
http://www.mynismo.c...?id=5577&rsku=0
You can use this for sealing up projects like:
  • Projector retrofits
  • Reflector changing
  • Lens replacing
  • JDM painted
  • LED accent lighting
The seleant is already soft so there is no need to heat it up before applying it.
How-to use:
1. Place a small bead of sealant along the inside of the trough of the housing where the lens would go. (The bead should only be about 1/4 of an inch thick. You should have a small amout of the original sealant on the housing already from when you baked it open.)
2. Place lens back in place .
3. Push lens and housing together as fimly as possible to make good contact with the sealant.
4. Place in a 300 degree Fahrenheight oven for about 5 minutes to get the sealant more pliable and seals better. (A heat gun works wonders also.)
5. While sealant is still warm and soft, fimly press the lens into the housing some more. Use clamps to keep it sealed if you have them.
6. Once it's all cooled down, it's sealed! Viola! Enjoy your newest finished creation that's sealed nice and tight! :)
['08 Xr-T - Silver Streak Mica] - 232whp/199tq
- GT28 Turbocharger, 525cc MWR injectors, FMIC, Powder Coated Black IC Piping, Forge BOV, 3" Downpipe - custom Turbo-back exhaust (TBE), 12psi
- ATS Spoiler, Shark-fin Antenna
- Weathertech Vent Visors (smoked)
- HIDs DDM 55w lows, 35w fogs (6000k, 3000k), Silverstar highs & turn signals
- Custom RX330 Projector Retrofit
- JDM Black Headlight Housings
- Back-lit Mirror Turn Signals, 3rd Brake Light, Red Dome Lighting
- Custom Blue/Red Gauge Cluster, ScangaugeII, Prosport Boost & Wideband AFR Gauges
- 20% Tint Rear 5 Windows
- TRD Upper Grille
- OEM Mud Guards
- Valor NVG-606W In-Dash Navigation HU, 10" Infinity Sub, Kenwood Amp
- BC Racing BR-Type Coilovers
- TRD STB, Front & Rear Sway Bar
- Energy Suspension Motor Mounts
- B&M Transmission Cooler
#2 RcMannAE86
  • 1,072 posts
  • Matrix XR-T
Posted 15 December 2010 - 02:29 PM
Just a few pics of my latest project that I used this sealant for sealing the housings up nice and watertight.
- TRD Upper Grille
- OEM Mud Guards
#3 MatrixNubee
  • 4,272 posts
Posted 15 December 2010 - 08:37 PM
Great find Ryan, I will def be ordering some soon :)
#4 RcMannAE86
  • 1,072 posts
  • Matrix XR-T
Posted 15 December 2010 - 08:41 PM
Thanks dude.
Oh!! And one roll is enough sealant to seal approximately 2-3 sets of housings!
- TRD Upper Grille
- OEM Mud Guards
#5 Shadow Trix
  • 2,297 posts
Posted 15 December 2010 - 09:56 PM
View PostRcMannAE86, on Dec 15 2010, 09:41 PM, said:
Thanks dude.
holy crap that's a good deal! very nice find :)
2009 Audi A4 Quattro 2.0T 6SPD
2005 Toyota Matrix XR
My Wheels Are For Sale! Check Them Out!
#6 keithvibe
  • 4,715 posts
  • TURBO AWD Vibe
Posted 16 December 2010 - 05:48 AM
Just an FYI
There are other products out there that are A LOT cheaper.
Such as window sealant for a car's windshield.
But, yes the nissan OEM sealant works very well.
UR Facebook
View Postdnm, on 27 March 2012 - 02:18 PM, said:
Fair enough, and I'm happy to be wrong. I am a lot.
#7 dnm
  • 9,315 posts
Posted 16 December 2010 - 08:14 AM
I used the stuff that came with my projector kit. Worked beautifully.
#8 Shadow Trix
  • 2,297 posts
Posted 16 December 2010 - 11:12 AM
View Postkeithvibe, on Dec 16 2010, 06:48 AM, said:
Just an FYI
will you be able to open it again though if you use that?
#9 keithvibe
  • 4,715 posts
  • TURBO AWD Vibe
Posted 16 December 2010 - 11:33 AM
if you buy the rubber butyl type, yes.
UR Facebook
#10 RcMannAE86
  • 1,072 posts
  • Matrix XR-T
Posted 16 December 2010 - 05:12 PM
Yes. This oem Nissan headlight sealant is a rubber butyl type sealant. It isn't goey to the touch until it is heated. You will be able to reopen your headlights the same way you did the first time with it.
Yes the sealant that came with the projector kits works great, but can be very messy if not handled right since it is very goey and pastey. But if you don't already have a sealant, or want a clean non-messy kind, this is the way to go! I've also noticed the our grey OEM sealant as well the grey sealant that comes with the projector kits start to form toxic fumes once heated in the oven. This rubber butyl sealant from Nissan/Nismo doesn't fume up and is easy to use.
- TRD Upper Grille
- OEM Mud Guards
#11 Madstyle
  • 9,495 posts
Posted 16 December 2010 - 05:48 PM
http://www.bestmaterials.com/butyl-rubber-...caulk-1103.html
Waaay Cheaper.
#12 RcMannAE86
  • 1,072 posts
  • Matrix XR-T
Posted 16 December 2010 - 05:59 PM
^that's some great stuff and it is way cheaper but it says it's double-sided tape, whereas the sealant I listed is the actual stretchable sealant that is moldable into wharves you are working on. I'm sure you can get it cheaper at different places but Nismo is where I personally got it from.
- TRD Upper Grille
- OEM Mud Guards
#13 Madstyle
  • 9,495 posts
Posted 16 December 2010 - 08:06 PM
It's not tape per say, It's still sealant the self adhering allows you keep it place while installing a part or sealing a part place in oven it softens, then completely close it.
#14 Ericss81
  • 29 posts
Posted 11 August 2012 - 02:29 PM
Can you guys give some links to a good projectors? The ones RcMannAE86 pictured look great but are they good quality lances? I know Acura and Ifinity have one of the best projectors. Any aftermarket ones with similar quality? Or just look for used from these automakers at the junkyard?
#15 Whosjorgey
  • 1,940 posts
Posted 11 August 2012 - 02:31 PM
^ it'll save you a lot of cash buying them at a junk yard, I paid 15$ for a pair of Lexus sc400 projectors compared to 150$ from TheRetroFitsource. Com (which is a good website to check out)
Ex-DSM Member #3.
Check out my Web feature here: http://www.stickytag...t_item/matrix/#
#16 danimal86
  • 878 posts
Posted 11 August 2012 - 02:45 PM
http://www.theretrofitsource.com/
The Morimoto Mini Bi-xenon H1 are the easiest (what i've got) to install, but bulb selection in very limited. If i could redo it, i'd get the d2s Mini's. You have a much larger selection of bulbs to choose from. These two require a small amount of manipulation to the bulb housing. If you feel like going balls out and hacking the hell out of your housing, you can get the FX-R's
Installed: DDM 4500K 55w HID's Morimoto Mini H1 Bi-xenon Projectors (XB-35 Bulbs & Denso Ballasts),(E-Bay) SRI Injen CAI, Pioneer Avh-P3200DVD (With add-on bluetooth & Navi) Avic-X940 Bt, Infinity Components (front) RF Prime 6.5 (rear), DC Header, JL 500/1 and 10w6, TRD Axle Back Exhaust, Camcom, TRD STB, Progress RSB, Scion TC Wheels Stock 16" 5-Spoke, Scanguage II, VLED V3 Triton Brake Lights, VLED: Interior reverse and flashers,
Next: Fx-R 3.0 retrofit LS460 Retrofit, Rear Disc Conversion
#17 RcMannAE86
  • 1,072 posts
  • Matrix XR-T
Posted 12 November 2012 - 10:08 AM
^i definitely agree with Danimal. At the time I did my project, the morimoto d2s mini's weren't developed yet. I would definitely recommend the mini's. The lens and projector quality are both great. If you are looking for OEM hid projector quality, go to a junkyard and find Acura, infinity, or Honda s2000 projectors. Some Lexus ones are great too. Just be aware that OEM projectors are extremely expensive, which is why I suggest going to a junkyard or pick-n-pull first.
- TRD Upper Grille
- OEM Mud Guards
#18 Vipfreak
Posted 12 November 2012 - 12:10 PM
I'd also agree with the D2S over the H1s.
#19 danimal86
  • 878 posts
Posted 12 November 2012 - 01:56 PM
Has anyone here actually tried to do a non mini H1/D2S retrofit? I picked up a new set of FX-R 3.0's for really cheap, but i haven't made a plan about how to mount them.
#20 RcMannAE86
  • 1,072 posts
  • Matrix XR-T
Posted 14 November 2012 - 01:55 PM
Mine were Lexus RX330 projectors. Those were a PITA to retrofit but I got it done.
- TRD Upper Grille
- OEM Mud Guards
