5 Speed To 6 Speed Conversion?
217 replies to this topic
#201 dnm
    captain pants
  • 10,267 posts
  • Interests:Toejam, but not Earl; sequels to bad movies; hair in the drain; dog farts; and broken promises.
  • 2003 Matrix XRS/2004 Matrix XRS/2007 Supercharged FJ Cruiser/2004 Audi S4/1994 Toyota Supra TT/1983 Yamaha XS400/and the real gem: 1997 Nissan Pathfinder, bιtches.
Posted 11 April 2015 - 07:56 PM
Brass drift + one good smack == removed axles.
#202 trixienathanp
trixienathanp
  • 1 posts
Posted 11 May 2015 - 10:18 PM
Hello All,
this has been a very helpful thread, thank you for all the information.  I am getting ready to do a 5-speed to 6-speed conversion with a used transmission.  For anyone that has done this themselves:
1)  are there any hints, tips, tricks, pitfalls, that I should know about?
2)  I am setting this up as a daily commuter car, not a racing car.  What are your recommended brands for a good clutch?
3)  Besides the clutch, shifter knob, and transmission, are there any other parts we need to have ready?  (I have all the tools I'll need)
4)  Is there a certain type of synthetic transmission fluid that anyone would recommend?
5)  I have not purchased a shifter knob.  Where are you guys getting yours?  Ebay?
Thanks in advance for the help. I'll keep you updated.
#203 CORZRYDE
CORZRYDE
    A bit of a whiner ;)
  • 5,020 posts
  • Matrix XR SC w/ C60 swap
Posted 12 May 2015 - 02:41 PM
Hello All,
Read through this thread again, right from page 1. All the info you're looking for have been mentioned at least once.
2007 Matrix XR~THE LOOK~Speedway Blue~TRD oil cap~TRD CF engine cover~TRD Grille~TRD STB~Hella Horns~Tein S-Techs~Progress RSB~MB Motorsports Boost Wheels (Gold)~Ichiba spacers (15mm F, 20mm R)~colour matched projector retro headlights .....................
................................~THE POWER~TRD SC~TRD CAI~DeatschWerks 370cc injectors~GReddy E-manage Ultimate~MWR pnp harness~AEM UEGO In Line Wideband~URD AFR calibrator~C60 transmission swap~MWR Ultralight flywheel~Spec stage 1 clutch~Energy Suspension motor mount inserts~Speed Source brass shifter cable bushings~Speed Source extended push rod~TRD axle back exhaust
a295f0dc-55d0-4ddb-85d9-92ba80bf4be7_zps
#204 hughesjasonk
hughesjasonk
  • 684 posts
Posted 12 May 2015 - 03:23 PM
Hello All,
1) your axles will fit. you dont have to use the 2zz axle
2) Stage 1 or stage 2 exedy is ok my preferance is clutchmasters
3) new drain and fill plug seals also new axle seals. New Flywheel Bolts. And have a rear main seal ready just incase.
4) I use mobile 1 75-90 and it does just fine
5) a shifter knob is a shifter knob
If you are doing this on a daily communter that you are trying to get nice mileage out of I do not recommend that you do it. your 5 speed will give you better gas mileage over the 6 speed.
Hello All,
In his defence the thread is kinda old.
Duct tape is silver but silence is golden..........
MOD LIST
#205 CORZRYDE
CORZRYDE
  • 5,020 posts
Posted 12 May 2015 - 04:34 PM
^ good point. However, this topic can be searched in "all forums" and will give you a ton of advice. I've typed out the recommendations/procedures a few times and dnm has mentioned it way more times than I have.
#206 MyTrix05
MyTrix05
  • 3 posts
Posted 25 May 2015 - 01:48 AM
I just did a 6 speed conversion in my 05 matrix xr. I had a problem with the cables being too short. Called monkey wrench racing and the guys figured out over the phone what the mechanics or I couldn't figure out. My tranny came out of a celica which won't work directly because of the location of the shifter mechanism on top of the tranny. Monkey wrench had the solution for $285 which replaces the mechanism back to where I can use the clutch cables in my car. Other than the headache of trying to figure that out it was pretty smooth otherwise. Just thought I'd give a heads up in case it wasnt already posted in here. Had my car back a day and so far so good.
#207 CORZRYDE
CORZRYDE
  • 5,020 posts
Posted 25 May 2015 - 05:33 AM
It is mentioned in here about that, but yes you are correct.  CElica and MR2-s have their shifter linkage on the opposite side of the tranny.  It always fun doing this swap, ask me how I know.....
#208 hoooboy
hoooboy
  • 1,254 posts
Posted 25 May 2015 - 05:05 PM
It must be the smartest info I read for someone who only have 3 posts on MO.com.  Usually it's something about "how can I have LIFT with my 1zz??"  lol
SUMMER MODE
2005 Matrix XRS
Bragging Rights Thread
#209 bnmiss
bnmiss
  • 6 posts
Posted 25 October 2016 - 02:35 PM
Hi all, I am new to this topic, but fell into a nice shape 05 Matrix with 195k on the odo and now a nice brrrr'ing sound coming from the 5 speed manual transmission, which gets more pronounced at higher speeds.
I too want to opt for the 6 speed with slightly better and an extra mainshaft bearing. I have 2 options (but am open to suggestions for other potential suppliers of 6 speed matrix transmissions and even a total re and re package if the price is reasonable; I paid 3k for the car, so not much attachment, other than looking for a cost effective fix):
1. a JDM Celica transmission with 70-80k on it or
2. a 6 speed XRS transmission with 115k on it. Will either of these slide right in (I believe that both are from 03- 06 vehicles, but will confirm prior to purchase), other than having to change the speed sensor from the current 5spd to the 6 spd.
Does anyone have a good recommendation for a clutch... I'm only looking to get 100k out of this car, so a reasonably good and cost effective clutch should suffice.
#210 bnmiss
bnmiss
  • 6 posts
Posted 25 October 2016 - 05:32 PM
Sorry, should have mentioned that i'm in the Mississauga area, so most of the golden horshoe area is close by.
#211 thebarber
thebarber
    brapapapapapap
  • 12,754 posts
  • Echo
Posted 25 October 2016 - 05:34 PM
DNM might have a c60 he's willing to part with
thebarber%20winter%20echo%20signature_zp
#212 bnmiss
bnmiss
  • 6 posts
Posted 25 October 2016 - 07:06 PM
Thanks; those Echos go forever... I contacted DNM and will wait for his response.
#213 bnmiss
bnmiss
  • 6 posts
Posted 09 November 2016 - 07:56 PM
Hi all, does anyone know a good reputable wrecker in the golden horshoe area who may be selling a 6 speed transmission for an 05 Matrix? The price I got quoted around Brampton seems high compared to the prices given by others.
#214 dnm
    captain pants
  • 10,267 posts
Posted 09 November 2016 - 10:45 PM
The C60 I have is spoken for.  The other one I have is grindy in 4th when warm.  Not sure if I'm going to sell or attempt rebuild on that one yet.
#215 bnmiss
bnmiss
  • 6 posts
Posted 10 November 2016 - 09:46 AM
Any thought in the community if the 6 speed really is better/ will be more durable than the 5 speed? I can get a relatively low km (85k km) for about 850 cad or I can get the 5 speed rebuilt for about 1750 cad ( I only have one quote, so I don't know if this is a good deal) plus removal and reinstallation plus hardware ( clutch plate) for both options. Your thoughts would be appreciated.
#216 dnm
    captain pants
  • 10,267 posts
Posted 10 November 2016 - 10:59 AM
The 6 speed is a far better transmission in every way.
#217 thebarber
thebarber
    brapapapapapap
  • 12,754 posts
  • Echo
Posted 10 November 2016 - 02:11 PM
6 is best
#218 bnmiss
bnmiss
  • 6 posts
Posted 10 November 2016 - 02:34 PM
Thanks a bunch:)) this makes the decision easy.
