2003 Matrix Xrs Drl's
12 replies to this topic
#1 dasspr
dasspr
  • 965 posts
  • Toyota Matrix
Posted 12 March 2009 - 12:32 PM
2003 matrix xrs DRL
Why did a make another one you may ask? Because there is so much confusion and so many different ways of doing this that I had a hard time deciding which one to do!
At the end of the day I did this, took me 1 minute and YES IT WORKS!!! Please donít trash this thread with other ways or what worked or didnít work for you because I donít care! Keep it nice and simple!
Pictures speak for itself!
Above the pedals you will find this box!
This is pin 12
Itís the red and white wire, just cut the sucker and stop thinking about it to much! Leave it hanging to tape it! It still works FINE!
And here is my 1 min DRL
#2 SlammedNiss
SlammedNiss
  • Local Moderator
  • 2,319 posts
  • Interests:Computers, Custom Cars
  • Matrix Xrs Automatic
Posted 13 May 2009 - 10:20 AM
So, uh, does this also disable auto-lights at dusk?
People's misconceptions on adjustable suspensions usually come from a lack of knowledge.
Lowest Matrix on 19's - SOLD
Fluid - Need I Say More?
1 - Hydroholics 1-5 Kit
4 - Parker Accumulators
3 - Kinetik Deep Cycle Batteries
#3 weather spotter
weather spotter
  • 606 posts
  • Interests:Christ, Church stuff, weather
  • Matrix base
Posted 13 May 2009 - 11:38 AM
Yes it does, it totally removes all auto light functions. you now must manually turn on your lights. Tthe on/ off switch actually works now! Man over machine!
#4 TraderVic
TraderVic
  • 2 posts
Posted 20 October 2011 - 02:24 PM
Exactly what I was looking for! Thank you very much!! :)
#5 XR2003
XR2003
    Photobucket can kiss my A S S !!!
  • 15,614 posts
Posted 20 October 2011 - 04:10 PM
You have been looking for this for over 2 and half years? Posted Image
QUOTE (mistamatrix @ Nov 20 2006, 01:11 PM)I'm sick like that.
QUOTE (PEImatrix @ Apr 1 2007, 11:11 PM) The car is pissed at you for cuttin it's nuts off!
#6 TraderVic
TraderVic
  • 2 posts
Posted 20 October 2011 - 04:41 PM
No.
#7 vicious_matrix
vicious_matrix
  • 21 posts
  • Interests:Cars,Bikes,Graphic Design, MMA,
Posted 19 February 2012 - 09:49 AM
so if I wanted to put led strips in my headlights or have my fogs as drl I can just hook the power to the red wire that comes out of that box and it should work?
for fogs I would run the wire to a switch then to the lights for the on/ off option?
#8 keithvibe
keithvibe
  • 4,723 posts
  • TURBO AWD Vibe
Posted 19 February 2012 - 10:51 AM
No, not without re wiring your headlight switch and adding in a few relays.
#9 vicious_matrix
vicious_matrix
  • 21 posts
Posted 19 February 2012 - 11:24 AM
wow I just did this for the DRL's only took me 10 min.... Thanks guys!
#10 vicious_matrix
vicious_matrix
  • 21 posts
Posted 19 February 2012 - 11:28 AM
I might just run my aftermarket fogs..to an ignition switch so as soon as the car is running they com on, but have a toggle for them to... relays sound too hard for my knowledge
#11 yanbed
yanbed
  • 23 posts
  • XR's Matrix
Posted 15 May 2012 - 08:11 AM
Will work with canadian trix ?
#12 dialpforparty
dialpforparty
  • 1 posts
Posted 03 September 2014 - 10:27 AM
So I am importing my '07 Matrix from the US to Canada and need real DRLs.  My car currently has just the auto-lights for dusk.  Am I to understand that if I hook up this red wire to a 12v current from the battery that I will now have functioning DRLs, thus making  my car compliant with Canadian safety standards?
Since I don't have DRLs on my car, what will I find instead of this box?
#13 StrayGoose
StrayGoose
  • 30 posts
  • Interests:Diving, off roading, tinkering.
Posted 09 January 2015 - 08:39 PM
Your car comes standard with DRLs. If your DRLs were dissabled using a guide such as the one above, just reconnect the cut wire to get it working again.
