Factory Outside Temp Sensor Location?
4 replies to this topic
#1 Rxzruby
  • 25 posts
Posted 17 February 2008 - 12:00 PM
does anybody know where the sensor is located?
wondering if i could re-route it for inside temp sensor, if the harness was long enough.
why? i am looking to get an auto dimming mirror with built temp sensor and i would prefer the mirror display to read outside and the speedometer to read inside temps.
Thanks,
Rxzruby
2007 Matrix XR
Phantom Gray
#2 RiVoT
    a.k.a. VinDub
  • Moderators
  • 10,427 posts
  • VW
  • GTI
Posted 17 February 2008 - 12:21 PM
pretty sure it's in the cavity where the horn and fog lights are...
but fat chance you'll be able to reroute things as such. the mirror probably has a buit-in sensor, not one you can wire to an external one nor share it's readings with the car's connection. too much work for nothing.
яіvøт: 2010 VW GTI MkVI
#3 JALOOS
  • 2,881 posts
  • Interests:My Car, Computers
Posted 17 February 2008 - 12:54 PM
Wonder if the ecu uses the data from that sensor as well.
"I Started Out With Nothing And I Still Have Most Of It Left"
#4 trimovingxr
  • 1,891 posts
  • Interests:import cars, triathlons, golf
Posted 17 February 2008 - 08:02 PM
Outside temp sensor is located in front of radiator, down low, on the support bracket that the hood latch is attached to. You'll see the wire leading to it.
#5 camryvibe
  • 219 posts
Posted 17 February 2008 - 08:34 PM
Anyone happen to know the part number and/or price? Thinking it might be nice to get a second sensor, mount it inside the car, and wire it to a switch so either inside or outside temperature could be shown on the dash.
