Multiple Cylinder Misfire.. Possible Causes?
27 replies to this topic
#21 wantin150
  • 4,151 posts
Posted 08 June 2007 - 06:07 AM
View PostMangoMan, on Jun 7 2007, 07:56 PM, said:
Bad coil pack, had the same issue in my ES300 Lexus and it was a cracked coilpack. Change the coil packs around and I bet the misfires will change to different cylinders. Also only user Denso Iridum plugs everything else is shite.
The NGK IX's are popular here and have had no issues. Just another option for you.
"Knowledge is power. Ignorance is, well, ignorance"
"It doesn't mean that much to me, to mean that much to you." - Neil Young
2003 XRS 6sp- Indigo Ink Pearl
K&N Typhoon SRI
MagnaFlow Cat Back Exhaust
Continental Extreme Contact 215-50-17
Speed Source Cable/Base Bushings
Energy Suspension Motor Mounts
#22 rmesa1matrixxr
  • 2,970 posts
  • Interests:cars cars and oh yeah cars
Posted 12 June 2007 - 12:45 AM
Some Tech advice here Swap the coils as that is the most likely cause. Do not use Bosch platinum plugs the heat range of our engines is not good for those plugs they will foul out very quickly. If the coil swap does not move the misfire the check compression if compression is good your next step is to replace the injector. If you have and obdII scan tool that will give you a data list check fuel trim if fuel trim is negative % it is and ignition or compression problem if it is positive % you have a fuel problem. Let me know what you find.
Rudy
I think about marriage I also think about killing people on the freeway.
#23 Panzer
  • 122 posts
  • Interests:A little bit of everything
Posted 26 June 2007 - 02:12 PM
I just returned from the dealer. I'm on here trying to find where I can buy a fuel injector. My CEL came on and the dealer said the code is (as it reads on the reciept they gave me) is P0301 - Cylinder # 1 misfiring. They tried changing the plug and coil but it still misfired. The mechanic (who is very good) said it needs a new fuel injector. You may need two!!
He said it was likely caused from bad gas. How this helps you out!
2004 Matrix XR Indigo Ink
#24 TOYOTA_PaTRIX
  • 39 posts
  • Interests:I enjoy technology, filet mignons, body boarding, teaching & competing Brazilian jiu jitsu, mixed martial arts, Toyota & Honda vehicles and most of all raising my seven year old Ethan Kendall.
Posted 06 July 2011 - 06:54 PM
2003 Toyota Trix XRS with a blinking CEL, I put a dollar bill by my muffler and it sucked it in lol, my car seems like it's sputtering at stop lights and I feel a tremendous lack of power from the 2zz. Had a buddy hook up his iPOD and OBD-II Car Diagnostics read "cylinder 3 missfire". Any word on how this cat fixed his? I will try to move coil from cylinder 3 to 1,2 or 4 and run OBD-II Car Diagnostics once again. One question! One a scale from 1-6, how hard is it to remove the coil pack? Thank in advance!
Edited by TOYOTA_PaTRIX, 06 July 2011 - 06:55 PM.
"I don't usually f*** around, but when I do, I don't f*** around!" -PKC
#25 Salsa Guy
  • 1,864 posts
  • S/C 4WD
Posted 06 July 2011 - 08:44 PM
The hardest part is taking off the engine cover. It's pretty down hill after that. It's about a 1 on a scale 1 - 6 (east to hard).
05 Matrix XR 4WD & S/C. The Few, the Proud!
MODS:
Performance: TRD SC, AEM UEGO Wideband w/Auber Gauge, Vibrant/Magnaflow Cat-back, Oil Catch Can, Voltage Stabilizer/Ground Kit, DC Sports Strut Bar, Auber Boost Sensor/Gauge, Tranny Cooler, Alutec Lightweight Crank Pulley.
Others: DRL Mod, Fog Light Mod, Sunroof Auto Stop Mod, Hella Horns, Ceramic Brakes, VVTi Logo Ignition Coil Cover. Lowering Springs, Fog HIDs
#26 TOYOTA_PaTRIX
  • 39 posts
Posted 08 July 2011 - 09:38 PM
WOW! Coil packs 1 & 3 were completely shot, long cracks running down the pack. My only option was to grab two at O'riley, and they're going in tomorrow morning! My XRS hasn't had a tune up since '05, what do you guys recommend I do to get this car in it's best running condition possible? I just got my routine oil change & change my serp belt. Anybody vouch for Seafoam? My AC also feels like it is blowing weak, anything I can check or clean to increase it's performance?
I'm grabbing these two coil packs from here because the ones at O'riley were $89 a pop.
'03 XRS Coil packs
#27 TOYOTA_PaTRIX
  • 39 posts
Posted 03 April 2012 - 09:32 AM
Had this problem and replaced all my coil packs and the issue was resolved & my "Check Engine" light vanished! My next problem is my AC, I just replaced my AC/Heater blower motor, but now I need to see why my "Temp Gauge" shoots up then plumits back to normal.
#28 dnm
  • 9,307 posts
Posted 03 April 2012 - 04:04 PM
No need to bump a 8 month old thread to say me too.
